How to change revision ID?
Hi all,
I believe this should be very simple but i just couldn't figure it out.
For the new revision tool, they default the revision ID to 01,02,03
Where can i change the revision ID to our company standard for example
During Development Design phase our revision ID start with DD-01, DD-02 etc...
And for construction phase the revision ID start with A, B, C etc...
Can anyone help please?
See if the discussion in THIS THREAD helps.
Hi s2art, thanks for the link.
So please tell me if im wrong, after reading all the post. it is suggest we better leave the revision no as 01,02,03 etc... because once you start manually change the revision no to alphabet archicad will not continue the revision automatically?
Not entirely sure, as I haven't used it yet, but I think when you change from letters to numbers, or from numbers to letters, it will continue from the latest setting. So, if you start with numbers then change to letters it should continue to use letters from that point on.
