Document & Visualize forum
How to create a multi line text in the elevation dimension?
LeeJaeYoung
Why didn't you create a multi line in the elevation dimension?
AC25 5010 / AC26 4019 on window 11
4 REPLIES 4
DGSketcher
Champion
Select the text in the dimension (not the dimension graphics) then rt-click and you should have an option in the context menu to edit the text as required.
Apple iMac macOS Monterey / AC26UKI (most recent builds)
I just need to be able to set SL: FL: etc in the elevation dimension and save it to favorites.
I don't quite understand your thoughts, but I'm just giving my opinion.
I can't save to favorite, which is the advantage of Archicad, so I work twice.
Ah~~~
Did you tell me how to edit it?
I guess I misunderstood because the translator translated it strangely. ^^
DGSketcher gave the method... but here are screenshots of the steps.  After placing the dimension, select the dimension text box (NOT the dimension itself!), right click, and select Dimension Text Settings....  You will see the multiline option there.
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2, iMac Pro 10-Core, Radeon Pro Vega 64
