I don't ever print directly to a converter.
I just tried (Microsoft print to PDF as that is all I have installed) and it is asking me to type a file name.
Maybe the PDF converter you are using is automatically creating the file name for you?
I always Publish.
Set up a Publisher set to 'Save As' and set the file type to 'PDF'.
It will use the built in PDF converter (which I find is best anyway - others can have problems with fills) and the file name will be whatever you have called the layouts.
You can also 'Merge' all of the layouts into one multi-page PDF and in this case it will create a file with the name of the folder you place them in (you then 'Merge' the folder.
