How to remove background fill from zone stamp.
M Cochran
On every AC 20 project I am working on, all of our zone stamps have a background fill applied that I cannot turn off or seem to edit in any way. In AC 19, I am able to turn off this fill. Is there a setting in the Graphic Overrides that could be causing this or I am missing a setting somewhere?
Margaret Cochran - BIM Manager,Technical Designer
ARCHICAD 7-23
HP ZBook 17, Windows 10
13 REPLIES 13
Please, show me the exact definition of the Graphic Override Rules, not the list of Graphic Override Rules used in the Graphic Override Combination.
You may also check the settings of the Zone Stamp. Is it possible that the Zone Stamp is generating a background fill behind its text?
I don't think it is a Graphic Override problem.
It is a background fill to your text as Laszlo suggested.
What zone stamp is it?
Check the settings to see if you can control the text box fill on/off.
Sjuzi
Sorry, yes I went through all settings in GO, and it is same as the other one, here is screenshot also for zone stamp, there is background empty.
Sjuzi
Ok I got it, it was rule for cut fills... I don't understand why actually, but it is fixed. Thank you guys
