2014-01-20 07:45 PM - last edited on 2023-05-17 05:43 PM by Gordana Radonic
2015-08-24 09:14 AM
2015-08-24 11:29 AM
Barry wrote:I would assume the same - though the posts above ours are dated 2014, which suggests that for
I don't actually have this object and I have nothing that can un-compress a RAR file so the original download for it is no good for me.
Being a work machine I am reluctant to go looking for and installing something that can open it.
It is quite an old object (2007) so it could well be that it just doesn't want to work with 18.
2015-08-24 01:13 PM
Paul wrote:
What else do people do these days to delineate fire walls?
2015-08-24 01:57 PM
gpowless wrote:Thanks - a good suggestion. I was thinking about something along those lines as a last resort, though ideally want to be able to switch the fire rating symbology off without switching the wall off in some views - for example in cross sections, or detailed plans. where denoting rated partitions is not the purpose of the viewPaul wrote:
Composite and complex wall profiles have the ability to customize line types in between or on the fills that make up the CP. I use this feature frequently to identify vapour and air barriers, fire resistance ratings of different walls and different membrane types in fire separations.
For centreline simply use 2 fills with the same fill pattern and change the line between.
