How to set a font style throughout the project?
New to ArchiCAD. I was wondering if there is a way to set the default font style throughout the project? For instance I notice that there are numerous places where you are given the option to change the font style (elevation markers, window tags, etc.). I'm wondering rather than having to go in and change it for every item/location - is there someplace the default can be set to be a single font style everywhere? Right now it appears to be defaulting to Arial on the US version. I'm not talking about uniformly changing the size or formatting as I know that needs to update on a case by case basis - just talking about the font itself. Like from default to Arial to default XX. Thank you!
1 REPLY 1
Yes, you should go to all those places and modify the default for Fonts to the desired value.
Then you should save this as a Template file.
You could also modify these settings in Favorites just to be consistent.
