2014-01-03 05:18 AM
2014-01-06 01:01 PM
2014-01-06 04:32 PM
khairulfikri wrote:I can reproduce everything you've done. This is a little odd in light of the Help Center information on the hotlinked module functionality of 17:
The problem is that the Master ID doesn't seem to show on the zone stamp. I can see the Master ID added on to the zone ID under Tags & Categories, but the zone stamp only shows the zone ID without the Master ID appended.
Optionally, connect the Zone ID with its Zone Number to display this information in the Zone Stamp.I can't quite sort out how to get that to work as stated. Elsewhere, in the 17 new features guide, it says that the Zone Stamp 2 now does what you're asking for... but I don't see that (quickly) either.
• For example, a Zone with an ID of Bathroom in the source file is placed into the host file as part of a HLM with a Master ID of R213. Its Zone Number will then be R213Bathroom.
2014-01-07 02:22 AM
2014-01-07 03:10 AM
2014-01-07 03:37 PM
Karl wrote:Presumably if you use a zone stamp (eg. Basic Zone Stamp) with the ID enabled within it, then give the placed HLM a Master ID, the zone stamp will show that Master ID combined with it's own ID. I could get the zone ID to show correctly but couldn't get the zone stamp in the placed HLM to reflect all the information.Optionally, connect the Zone ID with its Zone Number to display this information in the Zone Stamp.I can't quite sort out how to get that to work as stated. Elsewhere, in the 17 new features guide, it says that the Zone Stamp 2 now does what you're asking for... but I don't see that (quickly) either.
2014-01-08 01:12 AM
2014-01-08 09:12 AM
2014-01-08 10:50 AM
2014-01-08 03:15 PM
2014-01-08 03:31 PM
2014-01-13 12:44 AM
Link wrote:Yep, I am here
Is Marton around?![]()
2014-01-13 12:48 AM
Marton wrote:Great! What took you so long?
Yep, I am here.
Marton wrote:You know I'd really hate to upset those documentation people, can't you go and bug the GDL programmers instead?
As a first step we will update the documentation to reflect only the available options.
2014-01-13 01:14 AM
2014-01-13 02:11 AM
Marton wrote:Thanks mate - that's all we can ask!
I will try my best to raise the priority of it.
2014-02-02 05:16 PM
I assume the reason this was not finished is it is tied up in the general implementation of RW access to IFC parameters from within GDL?Note: As with other elements, the Zone ID is extended by the Master ID of the module instance it belongs to. Optionally, connect the Zone ID with its Zone Number and display it in the Zone Stamp.
2014-02-05 01:25 AM
2014-10-20 07:53 PM
2014-10-21 01:27 PM
2014-11-07 08:25 AM
