How to show dotted slab line from the floor above in current floor plan
Hi
I want to show the slab line from the upper floor on my current floor slab.
There is a punch in my 1st-floor slab . (See Fig 1 & 2)
I want to show the outline of the 1st-floor slab in my Ground Floor this way ( See Fig-3)
Set your upper slab to 'Show on Home and 1 Storey Down'
It should now show on the storey below.
If it is not showing as dashed, then go into the Project Preferences > Legacy and set the line type for 'Below Home Storey' to what you want.
Great...... I got it.
Thanks a lot.
