2023-01-23 07:37 AM
I am trying to import this Linetype from CAD to Archicad. What should I do?
1. I want to import in paper size.
2. Is it possible? I just come in like this.
Solved! Go to Solution.
2023-01-23 08:03 AM
You need to convert the text to lines too.
2023-01-23 09:17 AM - edited 2023-01-23 09:24 AM
I don't understand what you are saying.
Or can I ask for a little longer explanation for the translator?
2023-01-23 09:36 AM
What you said is to draw it as a line and treat it as a symbol. ^^
2023-01-23 03:08 PM
Sorry. I’ll try and explain a bit better. Line types don’t recognise text or letters. You need to trace over the letter with lines and arcs so that the letters become 2D linework too.
2023-01-23 08:21 PM
thank you so much ^^
2023-01-24 08:35 AM - edited 2023-01-24 09:05 AM
is this the best?
The finish was not processed like the bottom part.
Can you make the beginning and end part handle well?
Actually what I want is to ask because I need now to end with a line with no arrows at the start and end points.
2023-01-24 11:16 PM
I don’t think there is a way to tell the line type to finish and start with a dash unfortunately.
2023-01-24 11:35 PM
No, not when it is a 'symbol' line type.
The 'dashed' line types automatically show a solid portion at the start and ends.
2023-01-25 02:35 AM
thank you ^^
