In section, wall and slab line is not showing
Roopa A
I am using AC 24.
In section, the wall, slab, roof line is not showing in section.
If it is in auto update mode, it is coming like this.
I have attached the image.
Thank you
Roopa A S
15 REPLIES 15
Roopa A
I tried now. But, No use, it's coming the same
Roopa A S
In my experience, Sections look like this when duplicate elements are in the same position.
You should check whether those walls, slabs, and roofs are duplicated. Probably the "Check Duplicates" Goodie is the best tool for that.
In Section, it is easy to check: just select and delete one of those Walls. If it is a duplicate, one of the duplicates with be deleted, and that Wall will be displayed with correct cut pens.
Farnoush Pourmoradi
I've got an issue. why the slab is not showing in my section view?
I've attached the image of my drawingScreen Shot 2023-03-27 at 5.32.47 pm.png
Is the slab layer turned off or is the slab modelled in the wrong layer and that layer is turned off?
Thanks for your reply Barry,
I'm not sure, how can I realised that It's modelled in the wrong layer?
If you can see the slab in plan, select it and see what layer it is in.
Then make sure that layer is turned on in the section view.
Otherwise in the section, turn all layers on.
If you still can't see it, view extents to see if it is possibly far above or far below your main model.
Learn and get certified!
