Interactive Component Scheduling From 3D-Documents
Tonic Arch
Beginner
Hi team.
Is there some secret to populating a component schedule with objects from a 3D-document ?
We use the 3D-document method for preparing reflected ceiling plans, and these typically incorporate many objects that describe lighting and electrical fittings.
We are also looking at incorporating FF+E schedules, particularly for RCP's but also for plumbing fixtures and appliances, within Archicad itself rather than externally in excel.
The main issue is with the RCP in 3D-document format.
Any objects in the 3D-document aren't populating in the component schedule.
Are we missing something ?
If the objects are copied to a regular plan ( ie; to a storey level ), the schedule will populate.
But doing this defeats the purpose of using 3D-document to depict RCP's.
Anyone know of a way to pursue this ?
The schedule scheme settings are depicted below; while providing this is not exactly helpful, it indicates what we're aiming to do is not really reinventing any wheels.
Rev 24 Build 3008
Windows 10 Pro
Core i7-6700 @ 3.40GHz | 32GB RAM | Quadro M2000
Tonic Architecture + Design | 7 Prospect St | Fortitude Valley
tonic.cc
Matthew Johnson
Schedules will only list elements that have a home storey, which means they have to be placed in a floor plan (or at least be attached to one. 2D Elements placed in an elevation, section, detail, worksheet or 3D view will not have a home storey and therefore won't schedule.
No secret workaround that I know of. It just doesn't work.
Matthew Johnson - POWE Architects
AC4.5 --> AC27 & Revit 2019 --> 2023
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit
I'd rather be sailing.
Matthew Johnson
thanks, Matt
Rev 24 Build 3008
Windows 10 Pro
tonic.cc
