There is no perfect solution for this...
but there is hope.
You have to decide upon a few things:
1 - do you want an automatic conversion or is it acceptable to do some manual work after a model is modelled & exported?
2 - do you want the client to load a CD and start walking or is it acceptable that he/she needs to install software first?
3 - does it have to be a PC & Mac-solution?
4 - does it have to be online, with a webbrowser?
Different tools give different results.
I have a short overview of different tools, but there are other possibilities.
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/tutorial/3dcourse/VR/realtime.htm
EON Fastview can export the model directly from ArchiCAD. Not available for all ArchiCAD-versions...
Some independent web-3D tools can work with VRML-models. ArchiCAD can export them and so can Cinema4D. Not sure which of the two works best...
There is a large set of solutions that works fine with 3DStudio (3ds max or Autodesk VIZ).
Some formats generate a real 3D-environment (Cult3D, EON, Shockwave, AXEL, ...), while others are pre-rendered and thus not 100% interactive (Quicktime, Swift3D/Flash).
If you want real interaction (that is, actions that get generated upon clicking) then VRML, EON, Cult3D, Shockwave and similar can do a lot of things, but it will be an elaborate work in a seperate program to prepare it.
Licensing: some applications are free to use, but require a license fee to publish, while others are expensive, but you can publish at will.
Compatibility: most work on PC-only. Web-tools are often also supported on the Mac.
Archicad27/Revit2023/Rhino8/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Sonoma+Win11
Archicad-user since 1998
my Archicad Book
