I don't think you can with the standard Archicad objects (but I don't use these so can't say for sure).
You have some control with the Australian Essential library but not for the dashed door swings - I think they are always solid (see attached image).
If you have a subscription for your license you will have access to the Aus Essential library through Graphisoft Australia.
Otherwise it is possible but you need to use objects that have these options scripted in.
I can't recommend any in particular as I have created my own.
Even then my door swings are solid.
CADimage maybe - they usually seem to have decent objects and you can trial them for free.
