Document & Visualize forum
Interior lighting hazy...
Llian
I used the recessed spot 20 with a 35% main intensity and 80% visible light but the photorendering is hazy.
What do I have to do to remove the "haziness"?
Also, what its the difference between the lighting adjustment in the photorendering settings and the recessed spot light setting?
Lilian Seow
LEED AP | cSBA
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
Thank you Lasslo…
Wrt the haziness, I’ve resolved it. It was the glazing wall!
Lilian Seow
LEED AP | cSBA
I do not have an answer for the hazyness.
The difference between the lighting adjustment in the photorendering settings and the recessed spot light setting is that whatever you set in the Lamp Settings Dialog affects only that specific Lamp element, while PhotoRendering settings changes will affect all elements in the Rendering Scene.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Thank you Lasslo…
Lilian Seow
LEED AP | cSBA
Labels
