Isolate Layer
brittsax
Hi is there a way to isolate a layer like in AutoCad? I particularly want to isolate all objects on the lighting layer but can't seem to find where to do it. Thanks !
AC25 USA • iMac 27" 4.2GHz Intel Core i7 | 16 gb ram • OS Catalina 10.15.7
Ransom Ratcliff
Turn on the Quick Layers Palette
It should be in the Window Menu, near the end of sub-menu, Palettes.
Select something on a layer you want to "isolate" and click "Hide Others' Layer"
This Palette also has its own Undo Que.
Ransom Ratcliff
RATCLIFF CONSULTING LLC
Charrette Venture Group
ArchiCAD 4.55 - 26
Autodesk Certified Professional in Revit
macOS + Windows
Ransom Ratcliff
Ransom Ratcliff
ArchiCAD 4.55 - 26
macOS + Windows
Got it, thank you!
