LABELS NOT SELECTING WALL ID?
rob2218
how to make the label object read properly?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
21 REPLIES 21
rob2218
Ok...I see the "Text/Autotext" but I can't then get a box with a line as the tag symbol? what gives?
i>u
Edgewater, FL!
SOFTWARE VERSION:
I see, so this is why you used the "Property Label 22" Label.
I checked the settings, and if you use the "Property Label 22" Label, then in the "Symbol Label" panel, you can set the Orientation of the Label to be parallel to the labeled Wall.
rob2218
How...?
How do I set that?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Ok, I'm done...it's Friday. Going to go have a 'Social-distancing Beer'......i'll tackle this Monday...again...
it's "these" types of minutia things that kill me sometimes.
i>u
Edgewater, FL!
SOFTWARE VERSION:
I don't know why, but you have to set the pointer in order to have this option active.(see attached)
rob2218
....and what does that do?
By setting the pointer as you describe?
i>u
Edgewater, FL!
SOFTWARE VERSION:
You get a pointer with some settings and control points on the plan vue.(see attached)
rob2218
thanks...but...
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Try changing the angle in "Label Orientation"
Using NCS Wall label 23
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
rob2218
I'm not using AC23....using AC22.
AC23 is still too slow on my machine.
i>u
Edgewater, FL!
SOFTWARE VERSION:
