Label tool
Hi All,
I made a custom object and I would like to use the label tool to label this object but I want the label to display a custom text field parameter I have inside the object. Is there any way to do this? I know I can make a schedule looking at the custom field but I have never used the label tool for this info.
Any help will be greatly appreciated.
Thanks,
I think this is not possible to do at the moment.
Another way would be to display the value of a Property in the Label if the internal parameter of a GDL Object could be used in an expression defining the value of a Property. However, this is not possible currently either. Hopefully, this is something that will be added as a feature later since it would be very useful.
Thanks for your replay LaszloNagy.
I ended up making a custom object but then ended up finding one already done.
