Lag while dimensioning
Hello there.
Has anyone experienced a significant lag while dimensioning objects ?
I get a 1 second lag after clicking each node and it's almost impossible to double-click to end the dimension string.
I am on windows 21H2, very good computer specs. This doesn't happen if I open the file on another computer.
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
4 REPLIES 4
I had this experience last week while trying to dimension storey levels in sections / elevations. Annoying.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
David Maudlin
ernest atanasiu:
Here is another post about a similar issue: Sizing running slowly.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I found the guilty object: it's a morph of a bicycle track. When I save it as an library part it's only 1372 polygons and still makes dimensions lag.
How can I optimize this ?
Sorry to revive this post, but how did you know that specific morph was causing the problem. We have a similar issue where the dimension tool is lagging.
Robert J. Garand
ArchiCAD USA 27-Build 5001 USA FULL
Windows 10 Prof (64 bit) - Intel i9-10920X CPU 3.50 GHz - 128 GB RAM - NVIDIA Quadro RTX 5000
