So I guess you have already found the relevant settings in the "DXF-DWG Translation Setup" Dialog ("Save Layout into" and "Place Drawings into" fields).
However, to answer your last question, I think if you save a Layout as DWG/DXF, the Layout will always be saved, it is not possible to save only the Drawings placed onto it as DWG without saving the Layout as well.
