Project data & BIM
Leaf Thickness in Door Schedule
Hello, I am currently working on a door schedule. I want a field which displays a doors width, height, and thickness. I decided to go with the Nominal W x H x T field. This field does accurately show my doors width and height, but it shows the wall thickness instead of the leaf thickness. Is there a different field I should use or am I doing something wrong? Thanks.
1 REPLY 1
Marc H
I believe you want Panel Thickness. The nominal size relates to the frame.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Learn and get certified!
