Document & Visualize forum
Level Dimension Rotated in different scale
tranthainguyen
I have a level dimension in plan view. It is rotated vertically when I change the view scale from 1:100 to 1:250.
Does anyone know what is wrong?
Thank you
NGUYEN Tran
Architect & Urban Designer
www.syntaxpd.com
Imac 27" Core i7 2.8ghz l 4Gb Ram
MacPro 2011
AC 18 & 19 AUS
5 REPLIES 5
Are you simply changing the scale in the plan window or are you choosing a different view in the view map?
If you are using a view, then check the view settings to see if it is set to 'Ignore zoom and rotation when opening this view'.
Versions 6.5 to 25
tranthainguyen
Hi Barry
Thanks for your reply.
I changed the scale in the View Setting Dialogue of a specific view in View Map. The level dim is rotated.
I checked what you mentioned but it’s not the one.
Still dunno why.
Thanks
NGUYEN Tran
www.syntaxpd.com
MacPro 2011
AC 18 & 19 AUS
I thought you might be changing views.
But if you are just changing the scale I am not sure why it would rotate.
Does the same happen if you just change the scale in the plan and not the view setting?
Versions 6.5 to 25
tranthainguyen
Hi Barry,
It’s happening the same when I change the scale directly in plan
NGUYEN Tran
www.syntaxpd.com
MacPro 2011
AC 18 & 19 AUS
tranthainguyen
Hi Barry,
I just figured it out what’s the problem is. I will explain in detail in the next post.
Cheers
NGUYEN Tran
www.syntaxpd.com
MacPro 2011
AC 18 & 19 AUS
