Project data & BIM
Library Part Parameter in Property Expression
I am making a property for zones and i need access to a library part parameter.
i have access in schedules from the fields options, but i need to use inside of a property expression.
Is this possible?
4 REPLIES 4
Unfortunately, this has not been implemented.
Library Part parameters and IFC properties are not available when creating expression-base Properties.
You can make a wish for this feature, we can vote on it and if it gets enough support, we can submit it to GRAPHISOFT for consideration.
If you do make a wish, please post its link in this thread.
where can i find this wish list?
Here:
https://archicad-talk.graphisoft.com/viewforum.php?f=46
I would probably post it in the "Documentation wishes" category.
