Listing the wall net surface area in the zone list.
elisb
Hello. I am trying to create a zone list in which to display the net surface of the walls surrounding an area. (toatal perimeter X Height - total surface of doors, windows). For example: in the balcony area calculate only the facade wall ( not to count the railing as a wall). Below i attached a photo of my example. Thank you.
Rajesh Patil
Select the railing walls and in "Model" rollout change the relation with zone to "No effect on Zones". Hope this will help you.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Rajesh Patil
Rajesh Patil
Hello Rajesh,
Thank you for your suggestion. It helped. 🙂
You are welcome 🙏
Rajesh Patil
