Lost the ability to select the text of dimensions-NOW SORTED
Hi everyone,
Been working with Archicad find for a couple of years now, moving from AutoCAD.
I've a bit of a problem and no idea how or why it's started to do this, but....
I can no longer select the text of dimensions. I basically need to change a value of 1352mm to 1350mm, but it will only let me select the dimension line and not the text.
ETA - it appears I can't edit any text, even if it's in a normal text box
What have I done to disable the editing of text?
Typical - just as I post that, I had a sudden realisatioN that I had turned the quick selection/magnet off.
All sorted now and apologies for the post!
1 REPLY 1
Woody,
Wouldn't you just adjust the model so that it dimensions correctly?
Scott
