Mass Study with dimensions ?
How do I add dimensions to a mass study with shading?
- In floor plan - i have chose NEW 3D DOC FROM FLOOR PLAN. Then added shading and dimensions but - its not really a 3d study as its only a plan ?
-Can I create a 3D view (top view wih shading) and add dimensions ? (dont appear to be able to do so in 3D right ?)
- should I copy and paste the top view with shading in to say a worksheet ? then add dimemsions ?
SW
4 REPLIES 4
daviiiiidave
in a real "3D document" you can add dimensions. its a little tricky but it works.
(1) Axonometric View - Top - Save View
(2) Make it a "3D document"
(3) Add Dimensions
https://helpcenter.graphisoft.com/user-guide/89083/
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
Is this with the morph tool or walls and slabs ?
thX
Also how have you enabled shadows - tried the same thing - axo or in plan - save doc as 3D - this part ok so far- i follow you.
However, when saved though, no shadows showing. In option views shadows in on. Thankx
daviiiiidave
its a mesh and a slab.
Cause its a proxy of the 3D, you have to turn on a proper 3D-style. in my case, I choose white model with shadows.
