Visualization
Material in File to Hotlink to Twinmotion
Johann_P
I have some challenges with materials when I hotlink a file and Direct Link to Twinmotion.
1) In the original file the glass shows as glass. Both in Archicad and Twinmotion.
2) I then hotlink the original file into a second Archicad file, but seem to lose some material info.
The panels are all set to the same material settings.
3) When I Direct Link the second Archicad file to Twinmotion, the hotlinked file materials still shows incorrectly.
Any ideas?
The original Archicad
The original Twinmotion
View of the hotlinked file in the second Archicad
Twinmotion view
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
3 REPLIES 3
Lingwisyer
Guru
Is that a curtain wall that is not generating properly? Have you tested hotlinking it into a blank file?
Ling.
I have moved this post to the rendering section of the forum.
Carstenem
Check you actually do have the material in the material / surface list in your 2nd AC file. It should not matter but worth go and might fixes your problem?
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Learn and get certified!
