2015-04-1209:33 AM - last edited on 2023-05-1812:24 PM by Gordana Radonic
I've imported 2 catalogue pages from manufacturer's window sill and head sections for use as 2D details on an archicad working drawing. They need to be mirrored to fit onto my drawing. Unfortunately, I cannot mirror the imported images on my drawing. I've then imported the same images onto a worksheet and tried mirroring again. No success. The mirror option is greyed out in my edit menu. Does anybody have a solution?
If you are adding a PDF with the drawing tool in 18 you can try to explode the PDF.
If you can explode it (depends on how the PDF was created - but most should work) then you will be able to mirror it.
One of the forum moderators. Versions 6.5 to 27 Dell XPS- i7-6700 @ 3.4Ghz, 16GB ram, GeForce GTX 960 (2GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
If you can live with a workaround, select the page, once placed on the plan or worksheet, and save it as a library object.
Then you are able to check the "Mirrored" button, or use the Mirro command.
_________________
--Roberto Corona-- www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Thanks for your many suggestions. It seems that Archicad does not handle imported images the same as other imported items. I've tried importing in different file formats - even standard JPEG and PDF formats but none of them work. Can an imported image be exploded? If converted into a library object, how can I delete some of its components?
What I actually need are standard domestic aluminium frame details. The blocky sills and heads provided with Archicad and Cadimage doors and windows just don't look convincing when detailing these in walls because they are too approximate. Archicad and Cadimage presume timber style door and window frames. I reality, most frames are now aluminium and these are far more complicated.
If you guys place an image file using the Figure Tool instead of the Drawing Tool, you will be able to mirror it.
Actually, that seems to be one of the few advantages of the Figure tool over the Drawing Tool.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
