Emre wrote:
This should be an easy fix for GS I hope? Are you able to specify the normal direction (the visible side of the glass pane) when using the PLANE command Barry?
In Archicad a PLANE is just a PLANE and there is no nomination of what is front or back.
Maybe by the direction in which the co-odinates are specified - clockwise / anti-clockwise?
I am just guessing as I don't know for sure if that would have any affect.
In my objects (not the current Graphisoft default library but they were based on the GS library some 20 years ago), I have the option of 'glass as a plane'.
So I can swap from a single plane surface to a solid prism with thickness.
I don't see that option in the GS cabinets now, but it shouldn't be too hard for them to add that in.
Whether that would ever happen or not though I couldn't say.
I am only assuming that the glass as a plane is actually the problem.
