Document & Visualize forum
Morph bodies cast a wrong shadow once converted as a 3DS file in 3DS Max.
deivimazniku
Whenever I have to create a custom door, furniture, etc., I create the shape with the slab tool, convert it to a morph and rotate it to be standing vertically. it looks good on an Archicad rendered image, but once I save the 3d file in a 3ds type, every morph type object has a weird shadow on it. I tried saving the file in as many options as possible and every time it has that wrong shadow on it. How can I fix that, since I use Archicad mainly for creating the 3d file and I render it on 3dsMax.
1 REPLY 1
Hello @deivimazniku,
Can you share here a picture to explain this ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 26 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2015 - 16Go RAM
