Project data & BIM
Multi-Line Zone Name
ClaytonHakes
Hi All,
This should be super simple IMO. All I want to do is have my zone name say:
Toilet
Room
In two lines like that so that it fits in a narrow space. I can't find any way to have the zone name be two lines, however. Does anybody know if there's a way to do this?
Thanks,
Clay
Gerry Leonor
if you are using an earlier AC version (pre-25) you can change the length of the field name by setting the Zone Stamp Width to "Fixed" & adjusting the Width Value:
AC25 | Win10 | 64 bit | 16Gb RAM |Intel i7 8700 @ 3.20Ghz
come join our unofficial Discord server
https://discord.gg/XGHjyvutt8
What version of Archicad are you using?
In 25 (build 4013) you can now label a zone.
Use the autotext label (with autotext for 'Zone Name' and you can stretch the width of the label text.
Otherwise you are bound by the parameters of the zone stamp you use.
Some may allow you to set a maximum width for the name or possibly the maximum number of characters per line.
Some won't let you do either of these - depends on the stamp used.
A little trick you can try is name the zone ...  Toilet\nRoom
The \n might invoke a carriage return in the zone stamp.
However if you use the zone name in schedules it will appear with the \n in the name.
So if you don't use the zone name in schedules, this might work for you.
Gerry Leonor
Thanks Gerry! This worked for me even though I'm using AC25 v4013
