Document & Visualize forum
NON square images [grass effect ]
Claudio Lima
hello !
why can't I make any NON square 3D grass using an IMAGE... !?
please see the video.
https://www.dropbox.com/s/fqme8po7si3a77b/TAPETE%20RENDER.mp4?dl=0
tnks
best
claudio
since ARCHICAD 3.42 to ARCHICAD 25
Emre Senoglu
what are the geometries made of? thin slabs or picture frame object?
it could be caused due to the difference in material settings - basic engine is what you see on your viewport and cinerender settings are what you see in the rendered image. these two are not synced, so if you change something in one, you have to manually change in the other as well.
AC26 ARM // MBP M2 Max // Ryzen 2700x | GTX 1660ti // UE5.1 | Twinmotion | Corona | Rhino
www.senoglu.dk
Hi Emre !
thin slabs
the error its only in GRASS mode, the material is the same in internal and maxon engine.
look this image.
