What happened to the "Read from..." when linking several autocad drawings to a folder. This option does not exist anymore in archicad 17?!
In the drawings manager, we used to select several autocad drawings placed on different layouts, right click we had the option of read from, now we have to link each file by itself one by one...
Yes, you need to have more than one drawings selected with an external source (like a PDF or DWG file). Then you can specify a folder for all of them to be read from. If you have only one item selected, you can simply select the source file, no need to select a folder.
I tried it in my AC17 copy and I have the folder icon when more than one such file is selected.
.................................................................................................... Get Archicad Tips at https://twitter.com/laszlonagy AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26 Loving Archicad since 1995
The examples you have showed are for solo projects.
The problem I am facing is in the teamwork projects, even if I have reserved all of the project the folder icon does not show, on the contrary the read from icon becomes grey when I select several linked files in the drawings manager.
I can confirm that for teamwork projects the Folder does not appear to link either PDFs or DWGs you have to go one by one.
eduardo rolón AIA NCARB Another of the forum moderators. Macbook Pro M1 Max 64GB ram OS X 10.XX latest AC26 US/INT -> AC08 Puerto Rico, BVI, Miami Vectorworks 2023
