Non printable notes objects/layers/functions
menantol
Hi!
It is common for me to add notes to drawings while discussing with the client. Ususally I write them on the relevant drawing on a non-printing layer in autocad. Eg "make doorhole wider" or something in that manner.
What would be the equivalent solution in Archicad. Ie the possibility to write text on a drawing in layout mode and then having it not print when printing from layout mode.
Any help would be appreciated. (Please refrain from bashing autocad, or telling me that "this function is not necessary". This has been dealt with in earlier posts.)
/Andreas
AA / Architect
AC26 • Intel Q9500 | 16 gb ram | Nvidia 3070 • Win 10
David Maudlin
Andreas:
Put the notes on a unique layer, then hide that layer before printing.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Andreas:
Eduardo Rolon
You can use the same procedure than in autocad. Differences are that you don't have a "no print" option for the layers you need to create a Layer Set for were that layer is off for print purposes.
You could also learn to use "MarkUp Tools" which will make things more automatic.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
menantol
Thank you for your quick answers!
I guess the simple solutions work best. New layer it is.
Mark-up tool I tried but I didn't manage to make it not print. It will have to wait 'til another day.
Have a good day!
/Andreas
AA / Architect
