Document & Visualize forum
Object 2D Symbols
TracyGA
I am trying to create some objects from some 3d files that I downloaded.  Typically when I do this I can open the object created and then change the 2D Symbol to what I want to see in plan.  This has always worked perfectly, but now when I try to do it, the object does not update.  Instead, it always shows me the 2D View (I'm not sure what the difference of these is supposed to be), which I cannot modify at all.  Is there a way to fix this?
Lingwisyer
If you are putting the linework of your desired 2D symbol in the 2D Symbol tab of the object script, the 2D Script tab should be blank (or fully commented ( ! ) out).
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Win10 | R5 2600 | 16GB | GTX1660
4 REPLIES 4
Lingwisyer
Check the 2D Script? The 2D Symbol will get overridden by anything in the 2D Script, so check there and delete if required.
AC18-23 AUS 7000
I am not really familiar with the process of scripting.  Do you have a suggestion of what it should say?
Lingwisyer
AC18-23 AUS 7000
Thank you!  This worked great!
Labels
