Document & Visualize forum
Objects from BIM-Cloud are appearing green in 3D and in renders.
Amalie
As the topic says I have an issue that objects downloaded from BIM-Cloud are always appearing green in renders and in 3D-view. The attached image is from the 3D-model view. I have tried renovation filters and different graphic overrides, and unchecked "Show contours" in 3D Styles, but none have worked. Any idea how to fix these settings? not sure if it matters here, but I'm using Archicad 25
Thanks in advance!
1 REPLY 1
Aaron Bourgoin
could be that the surface attributes are missing and Archicad is applying a "General" surface instead.
Think Like a Spec Writer
AC4.55 through 26 / USA AC25-5010 USA
Rhino 7 Mac
MacOS 11.6.5
