Omitting Beam Segment and Column Segment from Schedule of Elements
Voytek
Could anyone please advise how to omit Beam Segment and Column Segment from Schedule of Elements in AC25. I just would like to show Beam and Column. Thanks.
AC 5.0 to AC27 INT Full - Windows 10 Pro for Wokstations - Lenovo P70 - 2.8GHz Intel Xeon - ThinkPad Display 720 x 1280
2 ACCEPTED SOLUTIONS
In the schedule selection criteria, add a field 'Element type IS beam' or 'Element type IS NOT beam segment'.
Just depends how you want to do it.
The same goes for the column.
Thank you Barry for the quick response and another helpful reply.
13 REPLIES 13
When there are simple rectangular beams and Huanch beams (contains 3 segments) designed with segment option,
then it is not possible to list all beams in one single schedule. I have to list Hunch beams separately.
Is there any solution for it?
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
Could you show us a screenshot of how the Scheme Setup Dialog is set up and what is the resulting Schedule?
Hi Laszlo Nagy,
Ram - 16.0 GB
Archicad 9..., 24
Change your Criteria so it is:
Element Types IS Beam OR
Element Type IS Beam Segment
Hi Laszlo Nagy,
Here is I am sending screenshot by doing changes as you suggested though I have already tried it before.
Fields marked with arrow are not needed but still they are being listed, thus making quantities double or extra. (Same problem is coming with Coumn schedule too)Haunch beam 1.JPG
Ram - 16.0 GB
Archicad 9..., 24
That is because in your criteria you have both beam or beam segment.
A beam is a beam and has beam segments - that is why they are listing twice.
You want just one in you criteria.
If you want just the entire beam, just use beam.
If you want info on each beam segment, then use beam segment.
Hi Barry Kelly,
Thanks for suggestion but if you see earlier post in this thread, i have done it that too.
This problem occures when simple rectangular beam and segmented beams comes together in a project and we need schedule for simple beam as normal but for segmenetd beam we need listing for individual segment.
Ram - 16.0 GB
Archicad 9..., 24
