Override the outside/top and inside/bottom lines in Graphic Overrides?
Geof Gainer
In Composites, I have the outside/top and inside/bottom lines of my walls set at the default Line Pen 1, which is pretty heavy. They look ok in detail view, but at 1/4" = 1' plan view the lines blur into each other and look illegible. They would look a lot cleaner if the outer lines were thinner.
Is there a way to isolate the outside/top and inside/bottom lines in Graphic Overrides? I could use a different pen set for the drawings in the layout, but I'd like to keep Line Pen 1 to read correctly for other items in the same drawing.
AC fan since v 7. Currently on AC 26 Build 5003 USA FULL Apple Silicon,. 2022 Mac Studio, 32G ram. OS X 12.6.2
Unfortunately no, Graphic Overrides always affect the whole element.
Geof Gainer
Thanks Laszlo, Jared Banks has suggested a different pen set but that has drawbacks as well.
