PDF option vanished
hey
when i open the organizer-publisher, the PDF save option does not show. i can see DWG' DXF ets. but the PDF is not in the list. it was in the past' and the PDF printer exists in my computer/ how can i get it back?
5 REPLIES 5
If it is a 64-bit Windows XP, then here is the answer:
http://www.archicadwiki.com/Amyuni%20PDF%20Converter
http://www.archicadwiki.com/WindowsXP
it's not 64 bit' and even if it was - it suddenly happened after 3 years of using archicad on that same computer...
You can try uninstalling and reinstalling ArchiCAD and see if that solves it.
i was hopping to avoid that. thankyou
JaredBanks
Mentor
You could also try running the repair feature of the install disk. Put the install CD in the machine, proceed like you're going to install, but then you'll get an option to repair. That might work.
Jared Banks, AIA
Shoegnome Architects
