PM Master sheet with editable fields
Is there a way in PM 3.0 to create a master sheet with fields that could be changed in the individual layouts?
I know I could create auto text, but that’s limiting to the information used.
For example I would like to have a field for “area” where I would change the number in that field manually for each layout.
Also with the same rational, I would like to place a PMK in my master sheet, then on each layout be able to replace it with another PMK (while maintaining it’s settings ( i.e. scale, output colour..) instead of having to place it in the correct location with the right settings every time..
Thanks,
If this can’t be done than I guess I’m pasting this message into the wish list..
David Larrew
Unfortunately, you cannot currently do what you are asking in PlotMaker. You are limited to stay within the abilities of the Autotext feature - you could try to create a format for the Autotext to simulate what you want...
Same with your PMK - Master Layout request.
Looks like it goes to the wish list.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Djordje
Ace
Paste this into the wishlist, and don't forget the poll!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
