2003-11-11 09:57 PM
2003-11-11 10:18 PM
Link wrote:I haven't tested such a large size now by by printing, but it seems that when you adjust the size of the image AND the resolution, in the Photorendering Settings, this would automatically adjust the printed output size.
Am I missing something blatantly obvious or is this a problem?![]()
2003-11-12 12:10 AM
2003-11-12 07:15 AM
2003-11-13 11:38 PM
2003-11-14 12:37 AM
Link wrote:You cannot render anything that is not seen in the 3D window. IMHo not possible in any software, please correct me if I am wrong. Therefore, the rendering window has to be proportional to the 3D window in order not to have any blank background colored areas around the rendering.
The plan vies shows the extents of the camera. The next view, is of the 3D window extents. And the final view is where the problem lies. The cropping down of the photorender to the 3D window extents.
2003-11-14 03:41 AM
2003-11-14 07:55 AM
2003-11-14 08:27 AM
Link wrote:If you don't mind my asking, why not?
Unfortunately stretching or resizing the 3D window is not an option.
And as zooming out is not an option in our case either, I guess I will have to have two cameras for each 3D view. One close, and one further away.Again, why not? Why not just widen the view cone to get more in the image?
2003-11-14 11:01 PM
2003-11-15 09:34 AM
Link wrote:Well ... if the houses are more or less of similar size (which they presumably are, otherwise plans, S/E could not automatically fit) then you should also decide on the size and shape of the 3D window, predefine 3D views, and set the photorendering window to be proportional to the 3D window.
As the model is populated in AC, it is automatically reflected and positioned perfectly on sheets in PM.///We have it so dialed in, that having him constantly resizing his 3D window would seriously hamper his quick production times. This problem is our biggest hurdle to overcome in our final stages of development.
2003-11-15 10:47 AM
2003-11-16 09:08 PM
2003-11-17 12:33 PM
2003-11-17 09:12 PM
Link wrote:Ah. Sorry. Somehow had missed that image and Djordje's reply to it - problem with this new system...had read the beginning of the thread, then when logged back on there was a flurry of messages and didn't realize I had missed some in the middle!
Hey Karl
If you take a look at the image I uploaded in an earlier post, you'll see what I mean. I really can't explain it better than that image shows it. Basically we want the sketch render to show more information than the 3D window. It's all there in the 3D window, because we can stretch it, or pan around and see it. Obviously we don't usually want AC to render more than is needed, but I think if we specify the photorender window to be bigger than the 3D window, then AC should photorender what we specify - not relate back to only what is shown in the 3D window. Zooming and/or resizing the 3D window is not really an option - what if we have two photorenders from the same 3D window for example. And both are prelinked into a layout book?![]()
2003-11-18 04:40 AM
Link wrote:No way , Jose
