Well, I thought I'd be ever-so-clever and generate a sky cube from Artlantis, since it has parametric clouds for its sky. If it worked, then one camera set-up could generate any number of different skies by changing the cloud parameters.
I set up six cameras, each names with the names Eric gave, with 90 degree view angles. While the clouds/etc do stitch ... the illumination of each image varies so that the seams are quite noticeable. I did have radiosity enabled, but Artlantis does auto-exposure which would prevent getting matching images anyway I think.
Attached is a VBE screenshot after having substituted the images via Eric's instructions - looking at a cube corner ... with the lines of the cube clearly visible.
So, there is more to making these sky maps than just panning around...
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
