I've moved this thread out of the wish section, as color workflow is not something that can be addressed by ArchiCAD. It is something that can be and should be addressed through proper system setup tbough.
No computer system, even a Mac, comes with proper color profiles to achieve a match between screen and printer (or scanner). It is simply not possible for any profiles to be valid for any extended length of time. In addition, monitor and printer profiles are only valid for particular lighting in the viewing environment. Whatever the type of monitor, the colors that the monitor generates change over time for a variety of chemical/mechanical reasons. Ditto a scanner. Printers are a bit more stable because of the nature of ink... however the same ink will produce different colors on different papers and so a different profile is required for each paper type.
Further, the color gamut (range of colors) that can be displayed varies with each technology and there is not a complete overlap. (Hence the 'out of gamut' option when print previewing in Photoshop, since monitors can generally display a much wider color gamut than even 8 ink printers.)
You can, however, get very close to satisfactory results by color calibrating your monitor and creating appropriate printer and scanner profiles. If your monitor is color calibrated and your client's is too - you should both see the same image. Without calibration, there's no telling what your client will see.
ColorVision's Spyder line provides a mechanism for creating a calibrated monitor profile, and more:
http://www.colorvision.com/
(This is just one manufacturer, but since I have one that I've used to calibrate my Mac and PC desktops and PC laptop, I mention it. I have dual monitors on each desktop machine, and neither is the same manufacturer: the Mac has an Apple primary and a no-name secondary. PC has a Viewsonic and a Dell. Colors between the two monitors were not even close until each had a proper profile created.)
Trying to create a color profile with the Adobe Gamma miniapp is doomed to a poor approximation at best. I could never get my two monitors to match (so that an image dragged to span each had colors matching).
A spyder can be as cheap as $54 for monitor-only calibration:
http://www.amazon.com/ColorVision-Spyder2-Express-Win-Mac/dp/B000ES4PYU/ref=pd_bbs_sr_1/104-3659884-...
(Presumably the software is not as full featured as the more expensive bundles.)
I have the Spyder2 Pro ($171)... which only creates accurate monitor profiles - printer profiles are a print, adjust, repeat affair. I was not happy with the primitive printer profiling capabilities of the 'Pro' bundle. (The high end package lets you scan the printout to adjust the printer profile.)
Without a color-calibrated monitor, all time spent in Photoshop, or in creating custom textures in Artlantis, etc., is potentially wasted as you really do not know what colors are really stored in your file.
Here are some other links that might be helpful:
http://desktoppub.about.com/od/colorcalibration/Color_Calibration_and_Profiling.htm
http://www.creativepro.com/story/feature/11132.html?origin=story
http://www.amazon.com/exec/obidos/ASIN/0201773406/creativeprocom
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
