Views of details and worksheets do not save the Graphic Override settings (or Structure Display or Reno Filter) with the view - hence the yellow warning triangle.
However, you can still change the GO when you have the worksheet/detail open.
At first nothing will happen, but if you right click and choose 'Rebuild from model', the new GO will apply.
The view will now be using that GO.
Unfortunately there is no way to change it in the view settings.
You should see a warning message when you change the GO in the worksheet/detail.
Unless you have previously ticked the box not to show the message again.
