Document & Visualize forum
Properties | Expression based on Renovation Status
Josh CSNZ
I have set up a CONCAT expression to merge a bunch of various properties and text (for the sake of this example I'll refer to it as CONCAT-1.
I want the expression to present different information depending on the renovation status of the element.
I think what I need is an IF function, something like:
IF the element is new then show CONCAT-1,
IF the element is existing then show CONCAT-2,
IF the element is to be demolished then show CONCAT-3.
However, I am not having much luck at all with the IF function in the expressions.
ARCHICAD 18 - 25 (Build 7000 NZE FULL) | BIMcloud Basic
CADImage Tools Add-on (by Central Innovation)
Windows 10 Pro
Intel Core i7-6700K @4.00GHZ | 32Gb RAM
Dual Samsung S27F350 1920x1080
Nvidia Quadro K620
10 REPLIES 10
Josh CSNZ
If it's of any use I have pasted the expression I have at the moment, where I have attemped an IF function, I'm cleary missing a fundamental step of how the IF function works wither particular respect to the "logical" field but not sure how to tackle.
IF ( {Property:CategoryPropertyDefinitionGroup/Renovation Status}=new, (CONCAT ( {Property:B1 | STRUCTURE/Timber size}, " ", {Property:B2 | DURABILITY/Treatment}, " ", "(", {Property:B1 | STRUCTURE/Type \/ Grade}, ")", " ", ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), " with ", "Studs @ ", {Property:B1 | STRUCTURE/Studs}, " and ", "Nogs @ ", {Property:B1 | STRUCTURE/Nogs} )), - )
Windows 10 Pro
Nvidia Quadro K620
Rajesh Patil
Hi, I think you have made simple mistake in typing by missing " " signs . Renovation  = "New Status" and a the end "-"
do try and let me know if I am able to solve your problem 👍
Rajesh Patil
AC 09-25 | INT | WIN10 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
You would be better using the IFS statement instead of IF, which would be more direct. Make sure the return type is set properly and also the classification.
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 25
Josh CSNZ
Thanks guys,  I think I'm getting closer.
I ended up trying the IFS function as I have 3x logical tests (reno status').
Have only entered two so far.
Below is what I have updated to, but still comes up with syntax error.
I expanded out to hopefully make it clearer, I also included the default IFS fields as a guide.
Windows 10 Pro
Nvidia Quadro K620
Actually even simplify the IFS expression is still producing a syntax error.
Windows 10 Pro
Nvidia Quadro K620
Remove the square brackets. Square brackets indicate the statements is optional and brackets should not be included.
Values are case sensitive Values should be "New" and "Existing"
Gerry
Josh CSNZ
Thanks, so close, still coming up against syntax errors as I develop further.
I have done a screen recording https://youtu.be/vGhFH_tvyeQ
I have tried to develop further using IFS
The below works
IFS ( {Property:CategoryPropertyDefinitionGroup/Renovation Status} = "New", ( ( CONCAT ( {Property:CategoryPropertyDefinitionGroup/Renovation Status}, " ", {Property:B1 | STRUCTURE/Timber size}, " ", {Property:B2 | DURABILITY/Treatment}, " ", "(", {Property:B1 | STRUCTURE/Type \/ Grade}, ")", " ", ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), " with ", "Studs @ ", {Property:B1 | STRUCTURE/Studs}, " and ", "Nogs @ ", {Property:B1 | STRUCTURE/Nogs} ) ) ) )
If I try adding another expression beneath it doesn't recognize the second expression
IFS ( {Property:CategoryPropertyDefinitionGroup/Renovation Status} = "Existing", ( CONCAT ( {Property:CategoryPropertyDefinitionGroup/Renovation Status}, " ", ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), " to remain" ) ) )
If I try add to the end of the first expression, I stell get syntax errors.
IFS ( {Property:CategoryPropertyDefinitionGroup/Renovation Status} = "New", ( ( CONCAT ( {Property:CategoryPropertyDefinitionGroup/Renovation Status}, " ", {Property:B1 | STRUCTURE/Timber size}, " ", {Property:B2 | DURABILITY/Treatment}, " ", "(", {Property:B1 | STRUCTURE/Type \/ Grade}, ")", " ", ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), " with ", "Studs @ ", {Property:B1 | STRUCTURE/Studs}, " and ", "Nogs @ ", {Property:B1 | STRUCTURE/Nogs} ) ) ) ),( {Property:CategoryPropertyDefinitionGroup/Renovation Status} = "Existing", ( CONCAT ( {Property:CategoryPropertyDefinitionGroup/Renovation Status}, " ", ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), " to remain" ) ) )
If I try add square brackets like in the default I still get syntax errors.
Windows 10 Pro
Nvidia Quadro K620
The default looks like this.
IFS ( LogicalCondition1, Value1, [LogicalCondition2, Value2], ... )
If I just try replacing the fields and leaving brackets in place I would have thought that would work.
Windows 10 Pro
Nvidia Quadro K620
Success!!!
IFS ( {Property:CategoryPropertyDefinitionGroup/Renovation Status} = "New", ( ( CONCAT ( {Property:CategoryPropertyDefinitionGroup/Renovation Status}, " ", {Property:B1 | STRUCTURE/Timber size}, " ", {Property:B2 | DURABILITY/Treatment}, " ", "(", {Property:B1 | STRUCTURE/Type \/ Grade}, ")", " ", ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), " with ", "Studs @ ", {Property:B1 | STRUCTURE/Studs}, " and ", "Nogs @ ", {Property:B1 | STRUCTURE/Nogs} ) ) ), {Property:CategoryPropertyDefinitionGroup/Renovation Status} = "Existing", ( ( CONCAT ( {Property:CategoryPropertyDefinitionGroup/Renovation Status}, " ", ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), " to remain " ) ) ), {Property:CategoryPropertyDefinitionGroup/Renovation Status} = "To Be Demolished", ( ( CONCAT ( ( SPLITRIGHT ( {Property:ClassificationSystemPropertyDefinitionGroup/CBI Classification - Level 4 - 2019}, " ", 2 ) ), {Property:CategoryPropertyDefinitionGroup/Renovation Status} ) ) ) )
Windows 10 Pro
Nvidia Quadro K620
You can not have two expressions within the same expression sequence.
Use the ADD button to make a new expression sequence and place your second expression in it. The program will use the first expression sequence that is valid. Otherwise, all must be in the same expression.
Gerry
