As far as I know, multi-page PDFs only have page numbers, not page names.
The file itself has a name.
When publishing PDFs from Archicad the PDF file will take on the name of the item being published.
If it is published as a 'merged' PDF, then it will take on the name of the folder that was merged - but it will still be just page 1, 2, 3, etc.
If not merged, then each page will take on the name it has in the publisher list and will have just page 1.
So as far as I know you can change the name of the PDF file, but not the pages numbers.
Otherwise how do you tell the PDF to print pages 4 to 7?
You could probably create a contents page in the PDF, or maybe even save a sheet index from Archicad that might even allow hyper-links to each page (not 100% sure as I never use them), but still the pages will just have numbers.
