SOLVED!
Publishing - pdf plans crash Adobe Indesign files when placed
cassie
Hi there!
We are coming up against a pdf issue, our published plans are crashing Adobe Indesign.
Is there a publisher setting to remove the layers or complexity of the pdf when publishing.
(my work around is to open in adobe and save as other - remove detail) - it would be great to be able to skip this step.
Thank you!
1 ACCEPTED SOLUTION
Solution
You do have some options when you publish as a PDF.
For example you can turn layers off.
You will have to refer to the Help reference for what some of the other settings do.
2 REPLIES 2
Solution
Thank you!
Learn and get certified!
