Document & Visualize forum
Question about Auto-text (layout #)
I tried searching for this but didn't find anything. We have a big project (different layout subsets) And we use our own master for each page and a layout number and total page number (i.e. 2 of 5) on the master. So here is our question: Can you have the auto text reset for each new subset
14 REPLIES 14
We are still looking for help on this. Is the only thing around this to make an opaque text over the master on each sheet?
Eduardo Rolon
Yes
You have to create Subsets per each section and edit their numbering system. If you have subsets
A01
A02
then the layouts can contain numbers like
A01.01
A01.02
A02.01
etc.
In your master layouts you would place the following Auto Texts
Layout ID
Layout Number
Subset ID
Subset Number
you can read pages 414 and 426 of The Reference Guide
If you want to reset the total number of pages per section XX of 5 for subset A and XX of 10 for subset B instead of being a total of all the layouts (XX of 15) it cannot be done automatically. One workaround is to have a Master per SubSet and type in the total for each section.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
There is a little trick to kind of automating it.
On the last layout page of your subset place a drawing (any one) and rename (custom name in properties) it to something like "Last page number".
Resize it so it has only a small frame and move it off to the side of the layout page.
Now right click on it and choose "Set as autotext reference" from the context menu.
Here's the trick.
You only need the one master layout for the subset if that suits your needs.
On that master add the autotext with a Category of "Reference for "Last page number" and choose "Layout ID ref."
If you drag the drawing to another page it will display that layout number - which is why it must be place on the last page.
So on the master you could have "Layout ID of Layout ID ref."
"Layout ID" will give you the current layout number of the layout the master is in (i.e. the page number) and "Layout ID ref." will give you the layout number the Last page number drawing is placed in (i.e. the last page number for that subset).
For example "4 of 6".
I hope this make some sense.
Not sure if I have explained it too well.
Versions 6.5 to 25
Eduardo Rolon
Can't believe that 5 years later I still need to use this trick.
OS X 10.XX latest
AC25 US/INT -> AC08
wilson83
With v18 and the addition of the revision manager, I have been using the 'status' and 'status code' in the tags and categories of the layout to identify the page number and total page number of any particular subset. You still have to manually apply the individual page number for each but you can select all of the layouts in a subset and manually apply the total page number (or status code) for all.
The above mentioned methods did not work for me as the outcome would result in far to many masters for the purpose we use it for. Thought I would throw this one into the mix as well. Be interested to hear of any short comings.
Michael Wilson
ArchiCAD 9 - 22 (6021 AUS Full)
Win7 | 64 bit | 8Gb RAM | Intel i7 3.40 Ghz
Yeah, right ) Good trick, but how many times we will use chocks like this in workflow? GS needs to add #SubLayouts in autotext.
uisanata
Searched everywhere...
Is it possible to have an automatic text in the Layout ID?
Our office template includes file naming with the Revision ID of each layout among other stuff. We have to change each file name by hand, renaming the files exported by the Publisher.
Would be great to have an export option which names each layout based on automatic texts.
thanks
arch. ernest atanasiu
AC22/23/24 INT/GER/FR on Win 10 2004
If you are talking about publishing PDF, yes, it is very easy to rename a whole publishing set following a naming convention using autotext.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
uisanata
That's it! Thank you!
bouhmidage
Thanks guys ! that was helpful so much
even in archiCAD 21 this still need to be tweaked 😕
Archicad 23
Windows 10 professional
Archicad 21 now has a new autotext for 'layout number in subset' where you can choose the subset you want to use.
There are a lot of new autotext entries in 21.
Versions 6.5 to 25
I'm using the #LayNoInSubset to get the layout number on a specific subset. But the issue is, since that autotext property is linked to the subset you choose on the list, I have problems when I use the same Master Layout on a different subset (which is very important because I'm creating several subsets with the same Master)
It would be much better if the LaySubset number is auto-detected, otherwise I'd have to make a new Master for every subset, only to change that tiny thing, since the rest of the information is the same. And that's a workaround that would end up in dozens of pretty much identical masters.
Link
I guess it would be hard for nested subsets. Which one does it detect?
Link.
Get your ARCHICAD 25 Template HERE!
When you open the list, you can select any of the current subsets on the file, but the autotext displays equally regardless of what you choose (#LayNoInSubset) so from the beginning is quite confusing. Then when you are on a layout of the subset you chose, it effectively shows the number of the plan within the layout, buy if you use the same master outside of that subset, the text is only shown as "#LayNoInSubset"
Labels
