2021-11-03 11:34 AM
How does Red Shift compare to Twinmotion?
I see it’s included with the latest 25 upgrade so which should we use?
2021-11-03 11:48 AM
I don't see Red Shift in the latest update. Can someone point me to it? I thought it was to be included in update 3 next year?
2021-11-03 11:51 AM
It's only available for those with subscription and they require a 8 GB graphics card.
2021-11-03 11:58 AM
I have a SSA subscription and I see nothing on Archiplus to download. Can you direct me to the link?
2021-11-03 12:01 PM - edited 2021-11-03 12:02 PM
I think you can change the engine directly from the PhotoRendering Settings window. Unfortunately my MacBook Pro only has 4GB, so I can't see it.
2021-11-03 12:17 PM
@felcunha wrote:I think you can change the engine directly from the PhotoRendering Settings window.
Nope -- I imagine a AddOn has to be loaded first - But don't see any link or info??
2021-11-03 12:28 PM - edited 2021-11-03 12:38 PM
There was nothing special to download & install, except for the latest Archicad 25 update. Here's where I found it. I haven't had much of a chance to test it out yet.
2021-11-03 12:34 PM
Open Photo Rendering Settings. Select Engine: Cineware by Maxon then a bit further down select Renderer: Redshift. I would imagine like many of us, unless you have a TOP specification graphics card then you will be politely told you can't run Redshift. I can't help thinking Redshift will be serving a very limited user group for some time. I have a two year old Mac with an 8Gb Radeon Pro 580X graphics card and it didn't make the benchmark.
2021-11-03 04:09 PM
I wonder if Redshift will work with the new M1 Pro chips?
2021-11-03 04:19 PM
More info here... redshift-for-Archicad including hardware requirements
2021-11-03 06:09 PM - edited 2021-11-03 06:09 PM
There is also this article ... https://community.graphisoft.com/t5/Visualize-articles/Limitations-of-current-Redshift-s-integration...
2021-11-03 08:52 PM
Looking forward to checking it out on the new machine! Thanks for the links @Barry Kelly and @DGSketcher !
2021-11-03 04:23 PM
Found it and tried it out --- Thanks
I have a 3080 card and it works without any problems and is fast. However, it may be better than the standard but don't think its all that significant. i think we need some instruction videos on the optimum settings
2021-11-07 10:24 AM
Thanks for the comments and links
