Visualization
Rendered images in right scale?
I am a student. I want to deliver my perspective drawing in the scale 1:50. And, I would like it to be rendered. Because that looks better.
Is that combination possible, and how do I do it?
3 REPLIES 3
Dwight
There's no such thing as scale in a perspective.
Where would you measure to?
If you wish to render an orthographic view [like an elevation] to scale, it is tricky.
Once the rendering is made, paste it into an Archicad elevation view and scale the image by matching it to an analytical section or by measuring it to a known size of an element in the rendering.
For sharpness, always render more pixels that you'll need. Shrinking maintains sharpness.
Dwight Atkinson
How do you mean with perspective in scale, could you please elaborate or send a rendering!!
When I draw an axonomety or frontal perspective manually, I start with a floorplan that is in the right scale, maybe 1:50. Then I raise up normals, find the right heights and so on. I do not think I explain the whole procedure here. It would be too much .When my schoool tell me to make axonometry, elevation, perspective in certain scales, this is what they think of. So I thought that AC had ways to get the same results.
I can make a floorplan, elevation and 3d document in the scale I want.
I find it in the Document-menu.
Learn and get certified!
