Visualization
Rendering with cinerender
Hello!
I have a problem. When I try to render this bathroom with cinerender, I only get a black mirror. The reflection does not work.
Any suggestions?
1 REPLY 1
Carstenem
Look through this tutorial that will help:
The CineRender Reflection channel is part 5 of this CineRender Surface Material Series from ASM Techabse. Reflections are almost every where on surface materials, if not a sharp one then usually some blurred reflections. This is one of the most important channels to master, if you want to create realistic surface materials.
Link here:
Cheers
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
